spark plug help
Old Sep 4, 2011 | 02:05 PM
jmahle67's Avatar
jmahle67
Default spark plug help
hey guys so im in the middle of changing plugs and wires on an 07 mustang and i did the passeneger side #'s 1,2,3 and after i get the wires changed and the plugs in i start it up to move it and i get a horrible ticking noise and a rough idle, i do the wires on the other side and go back to the first side, and take all the plugs out inspect and put back in and same ticking noise, and then i change out to the original wires and same thing still. what is wrong here?
Old Sep 4, 2011 | 02:19 PM
jimkaray's Avatar
jimkaray
check to see if one of the wires is not snapped down tight at the coil pack and is shorting out.
Old Sep 4, 2011 | 04:55 PM
jmahle67's Avatar
jmahle67
So pulled everything back out and my plugs r getting the tip smashed in any ideas?
Old Sep 4, 2011 | 05:20 PM
jimkaray's Avatar
jimkaray
Well now that's scary. You must have the wrong plugs. Sounds like they are too long for your application and the piston is coming up and smacking the tips. This is not good to say the least. check the part # vs the application ASAP.
Old Sep 4, 2011 | 05:37 PM
jmahle67's Avatar
jmahle67
I checked part numbers when I pulled old plugs and compared they same length
Old Sep 4, 2011 | 06:30 PM
jimkaray's Avatar
jimkaray
What do you mean by smashed in then? The gap seems smaller then when you set it or the ground strap is pushed up against the electrode?
Old Sep 4, 2011 | 07:29 PM
jmahle67's Avatar
jmahle67
Its smashed against the electrode
Old Sep 4, 2011 | 07:43 PM
jimkaray's Avatar
jimkaray
this is happening to all the plugs so I can only say they are not the correct plugs. You said you checked p/n but its not clear if you replaced with the same part #. Post a side by side pic if you can and check the length again. Measure from where they seat to the head down to how far they extend into the combustion chamber.
Old Sep 4, 2011 | 07:48 PM
JimC's Avatar
Super Moderator
With your mods listed in the sig the only explanation is that you have the wrong plugs. Like jimkaray said, measure the thread length because a stock plug shouldn't stick far enough in that the electrode and ground strap are getting smashed together.
Also, make sure when you get it back together that you have the firing order correct on the 4 - 5 - 6. It doesn't go in order like the 1 -2 -3; it is 5 - 6 - 4 on the coil.
Old Sep 5, 2011 | 04:07 AM
jmahle67's Avatar
jmahle67
This is a completely different car than in my sig. Ill see if I can get pics later today after work but they r def the right part #
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
lmurf60
Sep 24, 2015 10:07 PM
