Possible Seized Engine. Need Help
Old Oct 19, 2011 | 03:23 AM
austin4391's Avatar
austin4391
Well i bought jumper cables from orielys and first tried to jump my car and failed because the cables started smoking. apparently orielys said it must have been bad cables. so i brought the battery in with me and they tested it for me. they said that the battery was dieing. i forgot the start up voltage was. I bought the battery a year and half ago from walmart (big mistake). It was to close to closing time for them to give it a charge so i am going to wait till tomorrow to try charging it if that fails i'm going to buy a new battery.
They said if i take off the alternator they'll test it for me. Does anyone know of a good place to buy a aftermarket alternator?
Old Oct 19, 2011 | 10:47 AM
kevinmalec's Avatar
kevinmalec
If you take your car to Autozone, they can check your battery and alternator. You can also check with them regarding the price of a new alternator.
Old Oct 19, 2011 | 03:27 PM
austin4391's Avatar
austin4391
Well now i'm just waiting for my new battery. I pulled the alternator out and I was told it was good. So hopefully its the battery. Or i am running out of solutions.
Old Oct 19, 2011 | 08:10 PM
Nuke's Avatar
Nuke
Be sure to turn the radio off before turning off the ignition. If you have one of the Shaker audio systems, they'll drain your battery. The amp doesn't shut off on some models.
I'm suspicious of your alternator. Even with a battery gone **** up, the alternator SHOULD have been able to maintain spark and enough power for most everything else unless you have some kick-azz amps.
Old Oct 20, 2011 | 11:22 AM
austin4391's Avatar
austin4391
Well the battery made it sound stronger. much stronger. did not get it started though. So now i'm back to ground zero. Could this be a computer program? Fuel Pump? Or Spark Plugs?
Old Oct 21, 2011 | 08:02 AM
kevinmalec's Avatar
kevinmalec
Sorry to hear you are still experiencing issues. A clogged fuel pump/fuel line or damaged spark plug would also cause the car to not start and/or stall out. Have you changed or cleaned the air filter lately?
Old Oct 21, 2011 | 08:56 AM
aero86's Avatar
aero86
have you checked the codes? can you hear the fuel pump? does it just crank and crank?
Nick Oliver
Oct 17, 2018 04:22 AM
MusicCity615
Sep 27, 2015 12:53 AM
TfcCDR
Sep 14, 2015 12:08 PM
wawagner82
Sep 13, 2015 09:02 AM
prophotog
Aug 26, 2015 11:55 AM
