Water Running??
Old Jun 19, 2013 | 01:41 PM
IamNobody's Avatar
IamNobody
Default Water Running??
I just got the BBK CAI and Diablosport tuner combo. I installed the CAI and then put the custom tune on. I am now hearing what sounds like water running through a pipe behind the dash. Is this just water circulating through the cooling system and I just never noticed it before?
Old Jun 19, 2013 | 02:03 PM
aaquib1992's Avatar
aaquib1992
Are you sure it's not an "air whooshing" sound? As that would be normal with a CAI. Is it only making that sound when you are on the gas by any chance?
Old Jun 19, 2013 | 02:18 PM
IamNobody's Avatar
IamNobody
No its not air whooshing sound. It definitely sounds like water gurgling through a pipe. And I hear it just sitting idle in park (It's an automatic). Seems to be behind the stereo. Maybe water going through the heater core?
Old Jun 19, 2013 | 06:27 PM
Nuke's Avatar
Nuke
I'd guess the heater core as you have. There's nothing in a tune that should cause that so perhaps you're simply being more... critical... (a.k.a. **** ) about how your car is responding to the tune.
Old Jun 19, 2013 | 06:33 PM
pascal's Avatar
pascal
S197 Section Modder-ator
The A/C drain hose is plugged, most likely.
Water from condensation can no longer evacuate so it's slashing around.
Old Jun 20, 2013 | 10:19 AM
IamNobody's Avatar
IamNobody
Ahhh...Good point. I'll check it and see.
Old Jun 20, 2013 | 10:23 AM
IamNobody's Avatar
IamNobody
I was thinking the same thing. Always have been critical when doing something like flashing firmware in a major component. Being in computer repair for 30 years I know the risks of flashing firmware and what can happen.
Nick Oliver
Oct 17, 2018 04:22 AM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
