Lifter noise?
Old 04-16-2018, 09:10 PM
Lewis Favors
Lewis Favors's Avatar
Default Lifter noise?
Steady tapping from passenger side valve cover. Increases and decreases with rpm. Sounds like a lifter/ hydraulic tensioner but not certain. Could not find a write up on this . I am unfamiliar with the 6th gen mustangs as i have only ever owned 5th gen. I am a resonably talentented mechanic. Just need to know how difficult the job will be before i tear it down as i need to accomplish the job in a single weekend even if every possible thing goes wrong. (Or if i am way off base and this is a common issue with these models that is as simple as needing an oil change.)
Lewis Favors is offline
Old 04-17-2018, 06:56 AM
GT Nate
GT Nate's Avatar
They do sell some lifter "quiet" stuff you can try. Says to put in the crankcase till the next oil change. If noise persists the you probably need to tear into it.
GT Nate is offline
Old 04-17-2018, 07:15 AM
ZEN357
ZEN357's Avatar
Could be a Cam Phaser.
ZEN357 is offline
Gun Jam
01-13-2013 07:02 PM
DSTANG03
05-02-2006 05:21 PM
musting
03-02-2006 10:03 PM
lnmech
01-19-2006 07:23 PM
Stinger
03-28-2004 09:06 PM
Quick Reply: Lifter noise?
