Lifter Noise
Old Mar 27, 2004 | 01:07 AM
Stinger's Avatar
Stinger
Default Lifter Noise
Howdy all!! Anybody have any ideas on this small problem im having?Ok here it goes, Well i bought a new Upper and lower intake aka Typhoon and a new throttle body and EGR also i picked me up a set of GT40P heads off Ebay ! Well the heads came with 600#pound Springs and the rest look very stock! Very clean heads only the Valves had some minor stuff on them well i cleaned them up,NO Porting! Well My problem is this i had no lifter Noise or any sounds until this combo was put on! We narrowed it down to #8 Lifter after we removed the rockers and pushrods from the car as it was running the Noise went away except minor tapping! Has anyone ever herd off a lifter going bad with out collapsing? We pulled it out and looked at them and they was good !Just Number 8 makes the Noise.So can i just replace 1 side of roller lifetrs ? meaning 5-8? I dont have enough cash for all 8 ! Or should i just replace the bad 1?They are getting oil . Well the car didnt make any noise before just seems odd it would just go bad ,unless it was on its way out . Any suggestions or ideas would be awsome Thanks very much Stinger--->
Old Mar 27, 2004 | 02:33 AM
roundman's Avatar
roundman
Default RE: Lifter Noise
600 lb springs? you gotta be kidding, right! that kind of spring pressure will wear out the cam in no time! no wonder it's making a noise if that pressure is for real.
Old Mar 28, 2004 | 02:10 PM
Stinger's Avatar
Stinger
Yea that is what the guy said the springs are rated at? Do you think this would cause the lifter noise? I replaced all the lifters and i still have same type of noise in #8 area , not as loud though. Im not using roller rockers though ! Im using stock rocker arms . Maybe i can put stock springs on , think that would save the cam? Thanks for advice any and all is very helpful ! Stinger--->
Old Mar 28, 2004 | 02:16 PM
roundman's Avatar
roundman
my racing friend with a 533 ci big block with cobra jet heads only runs 300 pound springs on a full roller cam with .700+ lift and roller rockers with a stud girdle. I've never heard of 600 lb valve springs, sounds like someone is bull ****ting you big time. try some stock springs and see what this does for you.
Old Mar 28, 2004 | 09:06 PM
vfast's Avatar
vfast
I ♥ Acer
he might meant 600 lift springs..still a very heavy spring for some old lifter..if the spring have shims then removing them will be the ticket and you can do this on the car..
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
