Potential Oil Leak
Old 09-28-2019, 05:48 PM
joe8512
joe8512's Avatar
Default Potential Oil Leak
Hello all,
I am not familiar with mustangs. I drive and F-150 and do most of my own servicing.
My girlfriend has a 2006 4.0 liter mustang and I recently went to check the fluids and noticed oil build up near the intake (where indicated below). The car is otherwise driving fine and has no CEL or DTC.
What is that hose that my arrow is pointing at? Any help in regards to the leak would be greatly appreciated. Thank you all!
joe8512 is offline
Old 09-28-2019, 07:47 PM
Moderator
JimC's Avatar
That's not an oil leak. It is part of the PCV and lets oil film get into the intake to be burned off rather than released to the atmosphere. Many of us put oil catch cans on to keep most of the crap out of the intake, especially those running boost on the 4.0.
JimC is offline
Old 09-29-2019, 02:09 PM
joe8512
joe8512's Avatar
Thank you very much for the info!
So any action items on my part? Is there a chance it's leaking and that's why it's covered the top of the intake?
joe8512 is offline
Old 09-29-2019, 05:41 PM
Moderator
JimC's Avatar
No it isn't leaking -- it isn't an oil line. There isn't anything for it to "leak".
It puts oil vapors into the intake, and it will coat your intake manifold unfortunately.
JimC is offline
Old 09-30-2019, 01:14 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Not a leak as others have stated but, there is an o-ring in that hose that if it's worn, cracked, or torn, you will get some dampness around that area. That being said, if the seal is bad enough, you will get a slight lean condition because you'll get some unmetered air going into the intake.The car can compensate up to a certain point but, it does affect your MPG and can cause a bog at take off or an uneven idle depending on how bad it is and still not throw a CEL.
Derf00 is offline
Old 10-03-2019, 10:38 PM
teetertotter
teetertotter's Avatar
By replacing the PVC valve, that should be done regularly? Not looking to install a catch can. I burn Top Tier and use Mobile 1 full synthetic. Car runs smooth.
teetertotter is offline
6t9 stang
03-01-2008 03:46 AM
rwelshman
08-02-2007 04:46 PM
gt884me
06-25-2006 02:07 AM
Milky
01-19-2004 02:08 PM
89muscle
06-22-2003 02:19 AM
Quick Reply: Potential Oil Leak
