Code P0141 O2 Sensor
Old Apr 26, 2020 | 02:40 PM
paulmorgan's Avatar
paulmorgan
Default Code P0141 O2 Sensor
2010 is throwing a P0141
I know its a heater circuit failure likely due to tot a bad O2 sensor and bank 2 is the passenger side.- and that this is the downstream sensor... But I can't find a diagram where on the pipe this is. I am guessing this is the sensor located on the cat as the pipe comes down ...? Does anyone have a diagram or otherwise confirm?
Thanks in advance
Old Apr 26, 2020 | 03:30 PM
artsvettes73's Avatar
artsvettes73
Up stream = before the cat
Down stream = after the cat. It would be the second inline
Old May 16, 2020 | 03:38 PM
Animaaaaal's Avatar
Animaaaaal
You can access them from under the car. Here's a photo of the component they connect to that attaches to the from of the Transmission pan and you can see the there where the o2 sensors connect to
Blackbelt
18
Aug 24, 2012 11:50 AM
bignickwaite
Apr 25, 2011 10:58 AM
02GTman
Nov 11, 2007 03:52 PM
avlon06
Jun 25, 2007 11:40 PM
STDA2001Cobra
Mar 1, 2007 05:11 AM
