Map lights problem
Old Aug 8, 2020 | 11:52 AM
Kroiden's Avatar
Kroiden
Default Map lights problem
Hi guys.
Recently I realized my map lights stop working properly: they do right in all situations except when they go off once inside the car with doors closed. Switches are fine because they trigger light status on/off, but this status only shows when door opens or forcing it sliding wheel at max.
Here's a video explaining that behaviour:
P.D.: Found another post with same issue and a fuse as culprit: https://www.mustang6g.com/forums/thr...s-issue.56257/ but my model (2010 v6) has another fuse listing. I know it must be a 10-15A fuse in the interior box but can't find any dome/map lights related one. Could it be Courtesy lights one? It's the most similar...
Old Aug 10, 2020 | 04:12 PM
Kroiden's Avatar
Kroiden
SOLVED
It was indeed simply a fuse, don't know which one, mechanic just tested with a multimeter and replaced the gone one.
92chickmagnet
Jan 5, 2008 02:05 AM
mendii310
Jun 6, 2007 03:09 AM
Stang_GT_91
Mar 18, 2007 03:20 PM
morg68stang
Jan 29, 2007 01:25 AM
03blkstang
Apr 21, 2006 12:59 AM
