O/R X-Pipe gasket?
O/R X-Pipe gasket?
Last summer I put on an O/R Pypes x-pipe. I didnt have any problems installing it other than accessing the studs and nuts on the passengers side of the car coming off the manifold. When putting the x-pipe in I thought it was odd that Ford had opted to have a ball and socket type joint on the driver side, but a flat flange on the passenger side...but thought no further than that because I was excited to get it on. Tonight I found a website about installating an O/R x pipe (a different brand but for the same engine and year car) and they talked about and even had a picture of a gasket that is meant to go on the passenger side flat flange. I did not have a gasket with my X-pipe, or if I did I didnt see it and its not on my car. Did you guys have a gasket with your X pipes?
RE: O/R X-Pipe gasket?
my h pipe came with this rubber-like gasket, worked great. the stock gasket that was on there worked fine too, just really needed to be tightened down. how did you use a rockstar can darkhorse? just cut it into the shape of a gasket, the walls of the can? thats genius.
trashxtrash
09-20-2015 10:49 PM
