lowering
Old Mar 7, 2006 | 02:51 AM
jpmustanggt's Avatar
jpmustanggt
Default lowering
how much does it normally cost to get your car lowered assuming you already have the springs and is there anything else i need to get when i get the springs?
Old Mar 7, 2006 | 02:54 AM
bb1211's Avatar
bb1211
Default RE: lowering
i got mine done for $200. all you need is the springs, unless you want to upgrade other parts of your suspension.
Old Mar 7, 2006 | 02:56 AM
jpmustanggt
what kind of springs do you have and how much did it lower it?
Old Mar 7, 2006 | 03:05 AM
03sonicgt's Avatar
03sonicgt
It'll only cost you about 250 or under for lowering springs, and that is all you would NEED. But if you get a severe drop, your gonna want shocks, struts, and caster camber plates.
Old Mar 7, 2006 | 03:06 AM
96GT248A's Avatar
96GT248A
If you want it done right, get new shocks and struts to go along with it. If you go lower than 1.5", then you'll need cc plates.
Old Mar 7, 2006 | 03:15 AM
Hyper00's Avatar
Hyper00
Can you do it yourself? Save a lot of money and builds pride into your car.
Old Mar 7, 2006 | 03:20 AM
Car_Ramrod's Avatar
Car_Ramrod
yea, depends on how much the springs you have drop the car. if its more than 1.5" you should get new shocks/struts, camber kit, maybe even a bumpsteer kit. if its 1.5 or less, you should be fine just installing them and getting an alignment.
Old Mar 8, 2006 | 07:41 PM
kcp1989's Avatar
kcp1989
it depends where you get them done and also consider since the center of gravity is being lowered and body roll is being reduced, you might have trouble hooking up through 1&2
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
NYstang
Sep 30, 2015 09:56 PM
