blower switch
Old Mar 16, 2006 | 07:39 PM
gouldie1903's Avatar
gouldie1903
Default blower switch
my fan for the heating/cooling will only work on the max settig. already replaced the switch. what could it be?
Old Mar 16, 2006 | 07:54 PM
03redGT's Avatar
03redGT
Default RE: blower switch
maybe its the motor relay, its supposed to run of several speeds, and its obviously not. check the fuses for it, then check the fan motor itself. maybe its on its way out, how does it sound, any wierd smell?
Old Mar 16, 2006 | 08:15 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: gouldie1903
Check out the blower motor resistor. That's most likely the problem. It should be mounted somewhere in the blower case close to the motor itself. Other than the switch, that's what controls the speeds. That's why it only runs on high. That speed by-passes the resistor.
Old Mar 16, 2006 | 09:31 PM
03redGT's Avatar
03redGT
[:@]resistor DUH not relay!!!!!! im an idiot[:@]
Old Mar 16, 2006 | 10:47 PM
monkeydude3's Avatar
monkeydude3
+1 it's the resistor. The max setting is on it's own completely independent circuit, that goes around that resistor.
Once you have the resistor out, have a look if it looks un broken try cleaning the connectors and re connecting... or for the few bucks get a new one.
I had a car come into my work that had that problem, and ended up that the resistor connector was just dirty.
George
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
jhawkr
Oct 30, 2015 01:55 PM
guitarman376
Sep 30, 2015 05:54 PM
Colin Ringle
Sep 15, 2015 09:27 PM
