Reduce Gear Whine?
Reduce Gear Whine?
I installed a steeda Tri-Ax shifter after going to the track and not being able to shift gears. I still have the same problem of the shifter being notchy and sometimes not going in.
But anyways, when I downshift or im at a high rpm, I hear a lot of whine. Is there a way to reduce this so it isnt as loud?
Thanks
Thanks
RE: Reduce Gear Whine?
did you make sure to take the plastic bushing off the old shifter and putting it on the ball joint part of the tri-ax? I have installed 3 tri-axs now, The gear whine will happen, infact I believe it is mentioned in the install sheet, that tranny noise will be more noticed, due to less noise insulators....
Also, if you're just driving and downshifting for a stop light or what not, you can coast, you will get less whine the lower the rpms that you try to get into gear at...
I would make one out of that gasket maker kit they sell at the auto parts store. It's green rolled up and looks like really thick paper. (this is what i did). I just traced around the base and cut out the middle works fine. Or there used to be a sponsor that sells them shifter gasket .com or something
i got the dame problems with my mgw i just installed. there is alot of gear whine from like 2nd to 1st. and it somtimes wont get into reverse. its olmost like it gets mad at me somtimes and wont go into revers and other times its real smooth. and somtimes its kinda clunky to get into gears.
The problem going into reverse? Try bringing the shifter left, into the spot between 1-2 (that point when ou move the spring over) then move over to the right and slide into R, should work like a charm
ORIGINAL: dlazrael
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
