miles
Old Mar 29, 2006 | 01:41 AM
cdonofrio's Avatar
cdonofrio
Default miles
my 02 gt has 110k miles and im not going to get rid of anytime soon. what should i do to maximize the performance and keep the car running for a lot longer. right now i have exhust and intake is on the way. im new to mustangs and my car is automatic so im wonder what mods should be on the top of my list keeping in mind the mileage. thanx
[IMG]local://upfiles/33195/E97A5684393E49A3AE8EA274F47839FF.jpg[/IMG]
Old Mar 29, 2006 | 01:46 AM
03sonicgt's Avatar
03sonicgt
Default RE: miles
Just be sure to get oil changes regularly and change all the fluids and take care of her. If you do, it will last a lot longer.
Old Mar 29, 2006 | 01:47 AM
stangc83's Avatar
stangc83
Default RE: miles
how much do you drive that thing. i have seen an 02 diesel with less mileage than your mustang. you need to somehow get rid of it and get a new one.
Old Mar 29, 2006 | 01:50 AM
cdonofrio's Avatar
cdonofrio
Default RE: miles
i just bought the car less than six months ago i drive about 50 miles a week. i had a ton of miles when i bought it but i got it for super cheap and its in great condition
Old Mar 29, 2006 | 11:11 AM
Chopper's Avatar
Chopper
Default RE: miles
I would get a shift kit installed in the transmission.Nothing crazy just something to firm up the shifts.This saves the clutches in the transmission from unnecessary wear and goes a long way in keeping the tranny alive.You can get a chip that will do the same thing but a chip won't change the tranny fluid or inspect for damage and wear.
Next I would change the brake fluid.Brake fluid draws moisture and turns brown.It's supposed to do this to keep water from pooling in the calipers,causing corrosion and lowering the boiling point of the fluid.
Now change the other fluids,all of them,power steering,coolant,oil,rear end,and make sure the A/C is carged comepletly and has plenty of lube oil.
You don't have to do this all at once but I'd do it soon.Most of this is to look for neglected areas.
Old Mar 29, 2006 | 11:20 AM
Emann0007's Avatar
Emann0007
Default RE: miles
If you want to increase the life of your tired auto get yourself a tranny cooler. SummitRacing sells a nice B&M cooler for about 60-75 bucks. It's a kit so it has all the lines and such that you need. It will help extend the life of your auto tranny. Performance wise, get some gears. And keep your oil changes regular. 3k miles. If it was/is well maintained, it shoudl still have many many miles left in it.
Old Mar 29, 2006 | 04:28 PM
rbstang's Avatar
rbstang
Default RE: miles
wow an 02 with 110k... jeez thats almost 30,000 miles per year.
Galactic
Apr 29, 2019 02:56 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
lmurf60
Sep 24, 2015 10:07 PM
heslekrants
Sep 23, 2015 04:02 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
