351W swap into 96-98
RE: 351W swap into 96-98
ORIGINAL: jmmorgan82
isnt it against the law to run an off-road mid pipe too??? if so, prob more than half the people here are violating the law
by law, you can swap in a newer engine into an older car as long as all of the newer engines electronics and smog equiptment is on the car...you can not put an engine older than the model year into a car
so, if you swap in a 351 into a 1994 Stang, by law, you need to have the entire drivetrain, electronics and smog stuff from a 1995 Cobra R.
If you want to put a 4.6 into a FOX, then you will need the same stuff, including all 6 cats...
If you want to put a 351 into a 99, then you can not legally drive it since the last year for a 351 is 1995...
now an engine like a 5.4 swapped in is technically against the law, but since it looks like a 4.6....technically, a 347 kit in a 302 is ilegal
Thats why you dont get caught...
or you live in a county and state that doesn't require e-checks. AKA where i live.
ORIGINAL: Twister
and to remove an air bag...so yes, they are breaking the law and if caught...
Twister
but to the origonal post. it would bee alot easyer to just put it in a 94-95 5.0 because all that would be is a motor swap. if you did it in a 96+ you would need a new trany, drive shaft, k-member, motor mounts and alot of time.
ORIGINAL: Dark_Horse
how did saleen get away with the S351? they made them up untill 2000 i belive
ORIGINAL: Dsmfighter
ORIGINAL: Twister
With that being said, the Yukon is getting an o/r Y-pipe
