rearend problem...
rearend problem...
i had a new housing installed, new 4.10 gears, Eaton Posi & upgraded to 31 spline strange axels, its now a few months later now and im hearing a metal on metal grind when im turning, like making a turn in a parking lot or coming to a stop sign and making a turn, what could be the problem?
RE: rearend problem...
i forgot t mention that, i did go with an eaton posi, sorry.... so you think its shims not alligned properly... anyone else think that or anything else it might be?
You could also add some Friction Modifier, and see if it goes away... If it doesn't, then I'd be more concerned w/ finding out about shims... I've just gone through a major ordeal w/ Rear Diff. work on my car....
JT
JT
