oiling system for turbos
Ok Im slowly peicing my twin turbo kit together and I need to come up with some sort of oiling system. Does anyone have pics of the feader for even a supercharger. Does it come out near the oil filter? Need some help. I know I will need to use a pump to get the oil back up to the pan as the turbos are attached at the end of my long tube headers. I just need to get some oil to these things. where can I get the fittings and stuff needed for this?
RE: oiling system for turbos
I dont know how much this will help, but on my friends 240 we had to drill into the oil pan and put a fitting on it to feed from there. He had all the fittings and stuff already ordered though.
I think he ordered some of the fittings from here ( Just guessing.. I have it in my bookmarks, so it was used for something or other at one point in time)
http://www.racerpartswholesale.com/
I think I need a double outlet fitting that feeds pressured oil from the oil filter area wherever the oil presure sending unit is, then I need to run 2 lines down to feed the turbos from there. Then I need to attach the drain lines to the turbos and run both of them to a pump that with send the oil back up to the pan to return the oil to the motor. AHHHHHHHHHHHHHH.......what a mess thanks
underneath your oil filter there is a plug, it comes out using a star socket deal. youll know what im talking about when you see it. that is for the feed. the drain needs a hole punched in the oil pan below the crank pulley, make sure you have about an inch between the hole and the pulley. you might consider ordering the parts from vortech or another sc, i can give you the vortech part number for the oil system. that or just find an elbow for the feed and a fitting for the drain and an oil line for each. vortech has a hole oil feed/drain package though. if you need the part # lemme know.
looked up the part number for ya, for the oil drain assembly the # is 4fh130-036, the feed assembly is 4fh130-026. i can take pictures of the setup tommorow if you need.
**oh totally forgot your doing a twin turbo setup, you'll need a t fitting for the feed and drain, like a line connecting both turbos with a t fitting connected to the oil filter feed. then do something similar for the drain.
09-10-2015 08:39 PM
