GT 2000
Those 4.30's will help greatly.
You will need to compensate for the added gear if you are racing from dead stops.
Some LCA's and upper's will be a great modification, the uppers aren't needed though...
get a eaton posi when you change the gears out, upgrade to 31 spline axels also, aluminum driveshaft, get a driveshaft loop also , swaybar, springs,shocks, control arms, sub frames, mass air, port the heads, strut tower, maybe rebuild the motor and go back in with some better parts
trashxtrash
Sep 20, 2015 10:49 PM
