Firewall Adjuster
Old Apr 14, 2006 | 05:43 PM
01yellowgt's Avatar
01yellowgt
Default Firewall Adjuster
I have a steeda Adjustable cable, with a Steeda firewall adjuster. The Firewall adjuster just does not seem to hold an adjustment for that long. Is seems just to loosen up.
The set screw is tight, but just seems it just wallows a spot in the plastic, and loosens up.
Is there a better firewall adjuster out there.
Or is it just to get rid of the firewall adjuster or just put some lock tight on the adjuster and screw it into the firewall(where the firewall adjuster is just there, and not causing a problem. Then do the clutch adjustment from under the car.
Old Apr 14, 2006 | 09:45 PM
orang04gt's Avatar
orang04gt
Default RE: Firewall Adjuster
Im running the upr one it has a locking nut on it. Havent had any problems yet. about 12,000 miles on it.
Old Apr 15, 2006 | 12:28 AM
SOHCtimes2's Avatar
SOHCtimes2
ORIGINAL: 01yellowgt
Omg, seriously....I have to readjust mine all the time and I wasn't sure exactly what was causing it, but I am going to assume its the same thing you're having problems with!
According to the install instructions... "If you loose the set screw, a small dab of silicone gasket maker on the threads will keep the Cable Adjuster from vicbrating loose." I am going to try that and hope it fuking works. I'm also going to check the cable under the car where it connects to the (whatever the arm is called that connects to the TOB) and make sure that is not coming loose.
Old Apr 15, 2006 | 12:33 AM
so1o2k3's Avatar
so1o2k3
mine seems to be fine, i dunno what brand it is but it has a blue ****
Old Apr 15, 2006 | 12:34 AM
SOHCtimes2's Avatar
SOHCtimes2
Uhhhhh I think I'm gunna buy this.
Old Apr 15, 2006 | 12:35 AM
SOHCtimes2's Avatar
SOHCtimes2
ORIGINAL: so1o2k3
Mine is blue...I am gunna check if its the cable gettign looser where it connects to tranny tho.
Old Apr 15, 2006 | 03:46 AM
01yellowgt's Avatar
01yellowgt
ORIGINAL: SOHCtimes2
I havent thought of trying the gasket maker. I might have to try it and see how it works. But dont think its going to help, might be wrong. So its worth a try.
so1o2k3
ORIGINAL: so1o2k3
Mines blue also.
Which one do you think is better that one from upr or this one
Old Apr 15, 2006 | 03:48 AM
SOHCtimes2's Avatar
SOHCtimes2
Oh wow, that one seems awesome too....I dunno. lol
Old Apr 15, 2006 | 03:53 AM
01yellowgt's Avatar
01yellowgt
thats what I thought two. dont know which would be better either
I will talk to the guy at one of the peformance shops here in town that installed the clutch cable for me and see what he thinks. I think almost anything is better than what we have now though. lol
Old Apr 15, 2006 | 11:24 AM
merlinsrealm's Avatar
merlinsrealm
I just bought the Steeda kit that includes there new Firewall adjuster.......The new one has a set screw simular to the UPR one..........
Has anyone had any problems with it yet? I have not installed the kit yet and if I need to buy a different adjuster I would do it now before the install........
Kit I bought
just the adjuster
