o2 sensor question
Old Apr 22, 2006 | 07:59 PM
ackuric's Avatar
ackuric
Default o2 sensor question
does anyone here change em at a certain interval? and where can you get em cheap?
i've heard o2 sensors fail quicker than spark plugs in stangs.
Old Apr 22, 2006 | 08:16 PM
REDSTALION's Avatar
REDSTALION
Default RE: o2 sensor question
well if u were facing the check engine light problem, then just clean them and install BBK O2 eleminators, thats what ihave done to my car after i instaled the X-pipe.
click here
Old Apr 22, 2006 | 10:25 PM
wildazme's Avatar
wildazme
ebay, is a place you can get them pretty cheap. also try www.rockauto.com
Old Apr 22, 2006 | 11:31 PM
Krusher's Avatar
Krusher
o2 sensors only need to be replaced if and when they fail, not at an interval. Your check engine light will illuminate and give off a lean code... a good mechanic (yes that is an important part) will check your fuel trims to see if the o2s are switching properly and if they aren't... they will find out why. Could be the baro pid or even a vacuum leak... o2 sensors occosionally are the culprit but not all the time... just fyi.
Jb145700
Aug 21, 2022 06:37 AM
04stangman
Sep 17, 2015 01:45 PM
Big Al's 03
Sep 16, 2015 07:31 PM
TfcCDR
Sep 14, 2015 12:08 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
