Help!! Underdrive Pulleys
Old Mar 23, 2004 | 10:42 PM
cldnails's Avatar
cldnails
Default Help!! Underdrive Pulleys
I have a 99 GT 5spd and I cannot remove the crank\balancer pulley. I was able to remove the center bolt with an 18" socket. Then I used the harmonic balancer remover tool to get the pulley off and all I ended up doing was stripping one of the bolts off the tool.
Any suggestions would be of great help!!
Thanks everyone.
Old Mar 24, 2004 | 12:41 AM
Chopper's Avatar
Chopper
Default RE: Help!! Underdrive Pulleys
Make sure you use strong enough bolts turned all the way into the balancer.The tool I used came with SAE threaded bolts,the balancer has metric threads,so you might have to buy some metric bolts.
Old Mar 24, 2004 | 06:14 AM
GSXRIntensity's Avatar
GSXRIntensity
Impact gun. Made my underdrive pulley set simple as cake.
Old Mar 24, 2004 | 06:15 PM
04ShakinSteed's Avatar
04ShakinSteed
I ♥ Acer
What is an impact gun, GSXR?? Where do you get one and how much??
Old Mar 24, 2004 | 08:16 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
03steed are you serious? you dont know what an impact gun is?
Old Mar 25, 2004 | 12:45 AM
04ShakinSteed
I ♥ Acer
Yeah, I am serious...I've probably saw one before, I imagine it is a compressor driven air gun? Sorry[sm=smiley13.gif]
Old Mar 25, 2004 | 03:21 AM
Snydaleid's Avatar
Snydaleid
Old Mar 25, 2004 | 02:43 PM
WHT00GT's Avatar
WHT00GT
ORIGINAL: cldnails
Thanks everyone.
before you put the balancer on, take the washer that is around the hole where the crank bolt goes. it should be black. if you don't take it out, you will get nowhere and you will also rip the living $hit out of the part that goes into that hole.(the nipple thing).
good luck
Jimmy
Old Mar 26, 2004 | 09:56 PM
cldnails's Avatar
cldnails
Thanks for your posts. The pulley's are installed.
Unfortunately I did not read the post before I got the crank pulley off and YES I did strip several bolts trying to pull it off before realizing that there was a washer there. For some reason it was glued to the pulley itself and it was inset enough to where we couldn't see it.
Oh well, I learned how to do it, and I'm better for doing so.
Thanks again,
Christopher Davidson
GimpyHSHS
19
Dec 19, 2023 01:12 PM
spdeplayer2
Oct 24, 2015 09:45 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
