help! need quick help.
Old Apr 28, 2006 | 10:55 PM
white 98 gt's Avatar
white 98 gt
Default help! need quick help.
hey guys, just got done changing the coolant. was leaking from bottom of thermostat housing a little. so i changed the o ring, filled up & ran for a little bit. still leaking a little. i KNOW it's not the intake runner. just on the bottom of thermo housing. thermostat sits in it's hole, then o ring on top, then housing. think it would hurt to take back off & put some gasket sealer on thermo housing?
Old Apr 29, 2006 | 12:13 AM
jweffrey's Avatar
jweffrey
Default RE: help! need quick help.
i have a 98 gt also and im just now having the same problem i talked to alot of people and they said its the intake manifold i tryed to change the same thing and its still leaking
Old Apr 29, 2006 | 12:17 AM
white 98 gt
the mechanic i work with came by & he gave me some of the good sealant he uses. we'll see what happens.
Old Apr 29, 2006 | 12:45 AM
dlazrael's Avatar
dlazrael
make sure you torque your bolts to the correct torque, and use correct gaskets :-p
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Dathan
Oct 5, 2015 05:52 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
mustangheaven
Sep 29, 2015 11:00 AM
