quadrant, adjuster and cable
Old May 3, 2006 | 05:09 PM
blk40th's Avatar
blk40th
Default quadrant, adjuster and cable
i just installed my upr quadrant,cable and firewall adjuster last night. i put the cable on the 2nd notch. the only problem im having with this is that when im cruising now theres a squeak. im almost 99% sure its the throw out bearing. does anyone know if thats due to its out of adjustment. the pedal is much stiffer now. when i first put it in it wouldnt disengage the clutch all the way to change gears. i adjusted it and i can rip on it now. also the pedal doesnt spring up like it used to. anyone else have these problems.
Old May 3, 2006 | 07:24 PM
blk40th's Avatar
blk40th
Default RE: quadrant, adjuster and cable
ANYBODY???
Old May 3, 2006 | 09:26 PM
veneno_pr's Avatar
veneno_pr
I've also installed the Steeda kit that includes the firewall aduster with the adjustable cable and quadrant. When I installed I had your same problem but I could adjust it better from the firewall adjuster. Still some folks that have Mustang say that the clutch should have free play, mine doesn't. My suggestion to you verify the fork just in case it's not loose .
Old May 4, 2006 | 02:17 AM
monkeydude3's Avatar
monkeydude3
i put mine on the 3rd hook. SAME KIT AS YOU.. I get the same goofyness with the pedal. LIke when the car is cold, it is stiffer and doesn't spring up. Once it warms up, it's smooth as silk and comes up instantly. I am gonna try greasing the cable to see if that helps. The squeak... I have no idea what to tell you. My car did that after I put in the clutch and I think it's just ford's great noisy throwout bearings. Unless something breaks, I'm not investigating a stupid noise.
George
Old May 4, 2006 | 11:57 AM
blk40th's Avatar
blk40th
very true. thats really how it is when its cold. its not bad but i just wasnt sure if it was right. also when i was installing the cable i pulled on the fork and it moved out but then i popped it back into place so thats ok. also i noticed a lot of metal shavings by the throwout bearing. like a dust of metal. everything still operates well though. but wow is it stiff. thansk for the info guys i didnt think i was going to get any responses.
Old May 4, 2006 | 05:52 PM
monkeydude3
i put in a new clutch and TOB and all so I have no real shavings inside yet. the shavings are probably from your clutch disc wearing (probaly normal) and the TOB wearing (again probably normal)
eventually i'm gonna try putting some grease in the cable to see if it makes it more consistant. I hate having to let the car warm up before I can clutch properly, but eh it's all heavy duty stuff
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
winner99
Sep 30, 2015 07:04 PM
