high reving NA setup
Old May 9, 2006 | 02:45 PM
boss281's Avatar
boss281
Default high reving NA setup
ive been thinking about staying NA, maybe getting stage 2 cams and heads but im not really sure about what else ill need and how much it will cost. is 350hp at the wheels a realistic goal????
Old May 9, 2006 | 03:07 PM
Supergreen's Avatar
Supergreen
Default RE: high reving NA setup
very realistic in my opinion. depending on the heads and cams ive seen a 60 hp increase. i think its doable. its good to see someone else looking for it the hard way. im also looking for 350 NA
Old May 9, 2006 | 03:11 PM
Fallstar01's Avatar
Fallstar01
You've got a Mach right? I guess with full bolt-ons and semi-radical cams you should make some decent power. Not sure about 350 at the wheels though.
Old May 9, 2006 | 03:12 PM
Niteryder's Avatar
Niteryder
ORIGINAL: boss281
From stock that means you have to pickup another 100+HP or so. Might be cheaper to go s/c.
Old May 9, 2006 | 04:05 PM
06mustang88's Avatar
06mustang88
i think 350 is definitely realistic for a mach. it's going to cost a lot more money, but if you're not worried about that, you can do it
Old May 9, 2006 | 04:07 PM
StickShifty's Avatar
StickShifty
i believe its a gt
Old May 9, 2006 | 04:10 PM
06mustang88
ORIGINAL: StickShifty
i believe its a gt
looks like the shaker hood from the pic [&:] but i dunno
Old May 9, 2006 | 05:19 PM
boss281's Avatar
boss281
its a GT i just have the cdc shaker hood. i dont really know what parts im gonna need. am i gonna need new internals??? if so what would you recomend. thanks
Old May 9, 2006 | 05:42 PM
Dragon02GT's Avatar
Dragon02GT
ORIGINAL: boss281
Talk to Code3gt. He has a N/A which dyno's at 342 rwhp. He has A LOT of money put into that car. To get close to 350 HP you are gonna be spending over 10g if you go N/A. You need a bottom end on that motor that will handle the high revs with a big cam. The bigger cams have a powerband that goes allt he way up to 7000 or so RPM's. Your stock bottom end will only handle about 6000 RPM, so you are gonna need forged internals, better intake (P-51 from Fox Lake is what I recommend), ported and polished heads, and probably a bigger cam than a stage 2, some type of grind in between a stage 2 and 3 or just go to a stage 3 cam grind. You would be best off buying a built shortblock w/ forged internals to start off. Honestly, if you don;t wann go much above 375-400 RWHP a supercharger would be the best route. If you wanna get more than 400 RWHP then you should buy a built shortblock, do cams and head work, new intake, and then supercharger. But that all depends on how far you plan on taking it. A supercharger will run you $4g's, which is much less than the cost of getting 350 HP N/A, and will give more HP. But if you don;t want that, just expect to spend a lot of $$$$$.
Old May 9, 2006 | 06:05 PM
rbstang's Avatar
rbstang
best bet would be buy a new shortblock.
