E-break light
Old 05-11-2006, 01:50 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Default RE: E-break light
It's 'brakes'.
Anyways, your E-brake lever could be loose and out of adjustment. This is usually what causes it to come on.
Dan04COBRA is offline
Old 05-11-2006, 02:21 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
"breaks" again!
mine did that when the brake fluid was low. pads were still ok though. same exact symptoms.
the ebrake lever is supposed to be self-adjusting, it has a ratcheting device between the lever and the brake cable that sets itself each time you pull it, so it shouldn't be out of adjustment or it's broken.
redass02gt is offline
Old 05-11-2006, 04:20 PM
shag5150
shag5150's Avatar
The same thing happened to my '02 GT right before I had my oil changed........So, I mentioned it to them and had them check it.......The guys at the dealership said that the fluid in the reservoir was sloshing back and forth under a hard stop......They said it was normal and topped off the fluid..........It never happened again........
shag5150 is offline
Old 05-11-2006, 04:45 PM
Dragon02GT
Dragon02GT's Avatar
Funny, I noticed my fluid was a little low. Hmmm... thanks for the help guys, much appreciated
Dragon02GT is offline
Old 05-11-2006, 04:48 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
btw, it talks aboot this issue in the owner's manual. reading is FUNdamental.
Old 05-11-2006, 04:57 PM
geetee03
geetee03's Avatar
thanx a lot everyone! i think i just need to top off the fluid because i don't believe my breaks are bad yet.
geetee03 is offline
Old 05-11-2006, 05:04 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
BRAKES
Old 05-11-2006, 05:17 PM
DR8907
DR8907's Avatar
ORIGINAL: geetee03
Yeah they arent. You have low fluid and thats it... I had the exact same problem and I was getting nervous about having to get a brake job then I checked the fluid and felt like an idiot for not thinking of it before and getting worried.
DR8907 is offline
Old 05-11-2006, 06:33 PM
Dragon02GT
Dragon02GT's Avatar
ORIGINAL: redass02gt
Wow, that makes so much sense. Now I am gonna sit down and read my entire owners manual because I have nothing better to do.
Old 05-11-2006, 06:35 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
ORIGINAL: Dragon02GT
there is an index, so you don't actually need to read the entire thing. and it doesn't take more than maybe 10 minutes to read it.
Quick Reply: E-break light
