What exhaust is in your convertible?
#41
RE: What exhaust is in your convertible?
ORIGINAL: Larmo
Thanks again, Gaspi.... so based on that logic, I may want to rethink my planned next mod, a CAI. If you're saying my system can't "expell" enough airflow as of right now, why would I want to push more air into it with a CAI? Does this make sense?
I'm going to put on a SLP LM II for now and see how that goes. Then, maybe a CAI w/ tune and then if I get crazy an x-pipe (likely high-flo catted since I have a vert).
If we're talking about performance modifications in the air induction and exhaust system, the filter is the only thing that is clogging up the system. But even that is terribly small an obstruction. I wouldn't even call it that. So, even with a K&N filter, you won't really have the "need" for a bigger exhaust. Factory stangs aren't underpowered for that reason--that's because of the engine's compression, valve timing, etc.
My recommendation: Do the exhaust and a K&N filter--not for the performance, but for the satisfaction it will bring you in the driving experience (sound and all). If you truly want performance and don't have deep pockets (lord knows I don't!), the best mods for a stock stang are underdrive pulleys and a modified gear/pinion ratio. The former will give you a REAL 20hp, and the latter, although it won't give you ANY extra horsepower, it will definitely make your car accelerate a LOT faster.
Bottom line: The only time you will notice big gains from an exhaust system is if you supercharge/turbocharge/nitrous the engine, or if you port your heads to have a higher compression (and thus bigger "lungs," so to speak). Don't mess around with bigger throttle bodies, MAFs, or bigger intake manifolds until you do any of these four mods.
However, I'm a big believer in getting satisfaction from just working on your car. The point of it need not be bigger hp numbers or acceleration, but rather changing your car so as to make the driving experience more enjoyable.
#43
ORIGINAL: Larmo
But by all means, put whichever one you want first--the CAI or the exhaust. You'll have more fun with the exhaust, but with neither will you actually have any noticeable power gains. :-) Does that make sense?
#46
GO SLP II with a prochamber. somewhat tame at a stop until you lauch and scare the hell out of everybody. I had flow's b4 and they sounded good(old school), but they don't compare to SLP. The sound is very unique and the quality is great.
#47
Love LOVE Love my entire setup (sound & performance)!!!
Get compliments everyday from strangers....
Now I just need to get my heads and cam done and I'm done....that will be my winter project.
#48
#49
Sounds great!!! A bit raspier than mine (didn't say better or worse...lol)...I will have my wife take vid over the long weekend and post so you can hear the difference.
Sounds real nice though!!!
dalefrancis88
09-11-2015 07:15 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
