just got my raptor shift light
Old May 11, 2006 | 05:14 PM
wwmost's Avatar
wwmost
Default just got my raptor shift light
im about to start the install but when i opend the box i saw that there were no wire taps soo i was kinda bummed. is there a special tap i need to use before i got out and buy some? any pointers for the install? also is there a eaisir way of pulling off the panel soo i can get to the wire for the coil on the passenger side. i dont want to scratch it all up cuz the plastic thing that is holding that panel on is on there pretty good. hear are the directions im using. http://raptorperformance.com/Ford/Mu...1999to2004.htm any other things i should know before i start? thanks
Old May 11, 2006 | 05:58 PM
97targa's Avatar
97targa
Default RE: just got my raptor shift light
Wire Taps suck...They cut the wire..pinching it sometimes and fall off. I would cut away a small part of the insulation
on the wire and solder the new wire to that, and then tape it up. When you take it part, if you do, you can always heat shrink wrap
the cut part of the insulation.
Old May 11, 2006 | 06:00 PM
stage2roush2002's Avatar
stage2roush2002
Take your time on it. It was a pretty easy installation, it just took time.
degner122
Sep 16, 2015 07:09 AM
Colin Ringle
Sep 15, 2015 09:27 PM
Mustangmalo
Sep 6, 2015 05:22 PM
amandahchase
Sep 3, 2015 10:09 AM
