Help please odd codes.
Old May 12, 2006 | 12:20 PM
Asspire's Avatar
Asspire
Default Help please odd codes.
My check engine light has been on for quite some time now, so I recently took the car up to autozone to
let them see what codes its throwin. It came up as P1445. I asked the autozone guy what this could be and he said
a purge valve. He said it would effect my mpg and cause it to sputter when im accelerating like it does now.
BUT. none of my regular mechanics have any idea what a purge valve is or where it is located. someone said
that there is more than one of them. Is it actualyl the purge valve that is throwin this code? Any help would be
greatly appreciated.
Thanks
Old May 12, 2006 | 12:22 PM
93BlackNotch's Avatar
93BlackNotch
Default RE: Help please odd codes.
You don't have a purge valve on your car... Auto Zone guys get paid like $7 an hour, so you can't take anything they say seriously....
Old May 12, 2006 | 12:23 PM
monkeydude3's Avatar
monkeydude3
there may be a purge valve for the EVAP system. I'd look into it, that is what controls the vapors from the fuel tank being let into the engine to be burned off.
Old May 12, 2006 | 01:40 PM
Tac2cul's Avatar
Tac2cul
Purge Flow Sensor circuit Input High
now the tricky part...location of the part.....which i have no clue
its part of the evap system search for cracked vacuum lines and such
Old May 13, 2006 | 11:29 AM
Asspire's Avatar
Asspire
thank you very much. now I know something to look for.
Old May 13, 2006 | 02:18 PM
cobrapony27's Avatar
cobrapony27
A P1445 code is EVAP Emission Purge Flow Sensor Circuit High Input. all it is does is purge pressure out of the gas tank into the intake instead of venting it to the out side. I dont remeber exactly where its at but usually they will be near the port that you use to put pressure on the evap system to test it for leaks. The port usually has a green cap and a green tag on it.
Old May 13, 2006 | 02:30 PM
Asspire's Avatar
Asspire
So what can I do to fix it ?
Old May 13, 2006 | 02:49 PM
cobrapony27
By the code that you got I would say the sensor is bad and needs to be replaced. But first I would check the wireing and make sure its not loose, cut etc.
Old May 15, 2006 | 01:26 AM
Asspire's Avatar
Asspire
thank you so much for your help
mrtrodonet
Sep 19, 2020 03:12 PM
piotrek53
Oct 13, 2015 06:54 PM
mustangchef
Sep 4, 2015 08:08 PM
timeformiller44
Aug 26, 2015 12:03 PM
dragman72
Aug 9, 2015 12:54 AM
