installing rear cobra calipers
Old 05-18-2006, 01:58 PM
Mark99GT
Mark99GT's Avatar
Default installing rear cobra calipers
Is there anything I should look for to improve/replace as I install the cobra rear calipers? Since I do have to pull the axles.
Mark99GT is offline
Old 05-18-2006, 02:38 PM
DIVER8374
DIVER8374's Avatar
Default RE: installing rear cobra calipers
If you don't already have gears get them and throw them in while you have it all apart!!!!
BTW get 4.10's !!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
DIVER8374 is offline
Old 05-18-2006, 03:21 PM
ShadowDrake
ShadowDrake's Avatar
ORIGINAL: DIVER8374
Have you actually had it apart? Replacing the gears in the rear is at LEAST an hour extra, the carrier stays in the diff when the axles come out.
Mark99GT, take a look here: https://mustangforums.com/m_1112743/tm.htm
Edit: There's not much along the way to replace, nothing that is convenient really... the gears are the closest thing but that's still quite a bit of extra time. If you're doing gears, upgrade to a 31 spline carrier and axles.
ShadowDrake is offline
Old 05-18-2006, 04:18 PM
Mark99GT
Mark99GT's Avatar
ok, thanks. I am seriously considering the 4.10s and may just bring it to a shop to have the gears and calipers all done at once. I was also thinking about the 31 spline axles. How important are they? this car is a dd and will probably never in its life see more than 400rwhp. To do the axles id need to buy the axles, a new carrier and a new diff. right?
Mark99GT is offline
drfister
05-03-2018 10:38 PM
dubarado
12-23-2015 01:16 PM
JonnyBlazeGT
11-03-2015 01:10 AM
Urambo Tauro
09-07-2015 12:47 PM
inyadreems
08-21-2015 09:10 AM
Quick Reply: installing rear cobra calipers
