GT VS MACH 1
GT VS MACH 1
I was wondering what gives the mach 1 that extra 45 horsepower. I know that the mach 1 is dohc not sohc like the gt and it also has stock 3:55 gears and a nice upgrade in its suspension. But other than that im not sure. Does anyone know?
RE: GT VS MACH 1
More compression too.
MACH I VS. MUSTANG GT
MACH I VS GT
Front suspension
springs:
MACH I - 600 lbs./in. linear (lowers car 1/2 in.)
GT - 450 lbs./in. linear
Struts:
MACH I - 35mm piston, Tokico valve shocks
GT - 32mm piston, valve shocks
Stabilizer bar:
MACH I - 26.5mm (1.04 in.) solid
GT - 26.5mm (1.04 in.) solid
Brakes
Front
calipers:
MACH I - Twin-piston aluminum painted
GT - Twin-piston aluminum
Rear
Calipers: Single-piston
Rotors:
MACH I - 296mm (11.6 in.) vented
GT - 267mm (10.5 in.) solid
ABS/T.C.:
MACH I - Yes
GT - Yes
Misc.:
MACH I - Subframe connectors
GT - N/A
Engine
Engine type:
MACH I - MOD 4.6L DOHC V-8
GT - MOD 4.6L SOHC V-8
Displacement:
MACH I - 4.6L, 281 ci
GT - 4.6L, 281 ci
Horsepower @ rpm:
MACH I - 305 @ 5,800
GT - 260 @ 5,250
Torque lb-ft @ rpm:
- 320 @ 4,200
GT - 302 @ 4,000 (manual)
Compression ratio:
MACH I - 10.1:1
GT - 9.4:1
Bore and stroke:
MACH I - 90.2 mm x 90 mm (3.55 in. x 3.54 in.)
GT - 90.2 mm x 90 mm (3.55 in. x 3.54 in.)
Fuel system:
MACH I - Sequential multiport electronic fuel injection
GT - Sequential multiport electronic fuel injection
Fuel requirement:
MACH I - Premium (91 octane minimum)
GT - Regular (87 octane minimum)
Exhaust system:
MACH I - Stainless steel with chromed rolled tips
GT - Stainless steel with poished rolled tips
Info taken here http://www.musclemustangfastfords.co.../0303MM_Mach1/
MACH I VS GT
Front suspension
springs:
Struts:
Stabilizer bar:
Brakes
Front
calipers:
Rear
Rotors:
ABS/T.C.:
MACH I - Yes
GT - Yes
Misc.:
GT - N/A
Engine
Engine type:
Displacement:
GT - 4.6L, 281 ci
Horsepower @ rpm:
GT - 260 @ 5,250
Torque lb-ft @ rpm:
- 320 @ 4,200
Compression ratio:
MACH I - 10.1:1
GT - 9.4:1
Bore and stroke:
Fuel system:
Fuel requirement:
Exhaust system:
breaking
10-02-2015 01:27 PM
