Cracked intake manifold
Looks to me like the problem is well known. Pretty ****ty for ford to call it a silent recall.
I think if your intake is cracked you need to pull your panties out or your *** and go raise some hell at the dealer.
http://bigclassaction.com/class_acti..._manifold.html
http://www.alldata.com/TSB/19/96191745.html
http://forums.vmag.com/mvmontana1199/messages/859.html
http://askbill.modulardepot.com/view.php?viewid=54
http://www.thesqueakywheel.com/compl...plaint2764.cfm
http://www.mn12performance.com/mn12-...b/R97M91dl.PDF
http://www.mn12performance.com/mn12-...b/R97M91a3.PDF
http://www.miracerros.com/mustang/2000_tsb.htm
http://www.flamingfords.info/manifoldhome.html
http://warnerrobert.com/cgi-bin/ubbc...=7;t=000297;p=
This link might be helpful for those who want to tackle repairing a cracked manifold themselves and saving some labor $'s. Lot's of information and very detailed instructions.
www.autoclinix.com
MDD
www.autoclinix.com
MDD
ORIGINAL: sheebeehuh
www.autoclinix.com
MDD
www.autoclinix.com
MDD
Don't blame me, I found a link directly to this post in Google. It may be an old problem but when my manifold blew 2 months ago it all of a sudden became timely to me. Also, there are a number of people who are not covered by Ford's lawsuit settlement (which isn't exactly settled yet due to some people contesting the proposed class-action settlement proposal).
ORIGINAL: Epd711
I just had the exact same problem on my 98 Gt. I brought it in cause antifreeze was pissin out, and i got charged for $1200 to fix. The mechanic at the ford dealer said the Crown Vic's had the same problem, and actually had a recall, but the recall did not even apply to the mustangs even though it was the same part. I got it fixxed for $1200, got my car back, and it runs like junk. I'm lookin into whether or not the mustangs had a recall on that intake manifold.
The P.I. manifold will fit with the adapter plates. I don't know much about them but I've heard of them and they will make a P.I. manifold work with non P.I. heads. The manifold will only help you a little if you don't have P.I. heads though...
My new one cost =185 or so and me and a friend did the swap, it has the aluminum front which is where they crack. There IS A RECALL IN THE COURT SYSTEM AND SHOULD BE DECIDED THIS MONTH. later
jwog666
Dec 27, 2021 08:09 PM
