Transmission Fluid
Old May 28, 2006 | 09:12 PM
03 GT's Avatar
03 GT
Default Transmission Fluid
The automatic takes Mercon V according to manual, what brand make synthetic Mercon V.. I cant find any synthetic...
Old May 28, 2006 | 09:23 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: Transmission Fluid
Click link http://mobil1.com/USA-English/MotorO...hetic_ATF.aspx
Old May 29, 2006 | 02:34 AM
monkeydude3's Avatar
monkeydude3
i think dexron III is the same thing. Most trans fluid I see are dexron III/mercon V labeled. Mobil 1 ATF is great stuff, I run it and the trans loves it (t45) i can't see how the 3650 is that much different
Old May 29, 2006 | 02:37 AM
03 GT's Avatar
03 GT
ORIGINAL: monkeydude3
The manual is very adament about only using Mercon V and that Dexcron/Mercon II and III are NOT compatible..
Old May 29, 2006 | 02:39 AM
monkeydude3
hmm... that's odd... cuz the mobil 1 that I run is labeled as "ATF" and it says can be used in either application
Old May 29, 2006 | 02:42 AM
03 GT's Avatar
03 GT
I actully found a Valvoline Synthetic Blend thats purely Mercon V. Thats probably what I will run..
Old May 29, 2006 | 02:43 AM
monkeydude3
yup whatever you would prefer. I think the mobil 1 is designed to work with both applications.
Old May 29, 2006 | 02:46 AM
03 GT's Avatar
03 GT
Thanks for the help
Old May 29, 2006 | 02:52 AM
monkeydude3
no problemo, g/l with the car
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 25, 2015 06:42 PM
