A/C problem
Old Jun 8, 2006 | 10:28 PM
ByPopularDemand's Avatar
ByPopularDemand
Default A/C problem
My a/c blows air but its not cold(or hot actuatlly) what should I do to fix it...Any ideas
Old Jun 8, 2006 | 10:31 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: A/C problem
Probly low on freon. (R134A) If its low then you have a leak somewhere.
Does the compressor run?
Old Jun 8, 2006 | 10:37 PM
ByPopularDemand
How do I check if the compressor is running
Old Jun 8, 2006 | 10:43 PM
sprostang's Avatar
sprostang
I ♥ Acer
Turn on the A/C and check and see if its turning. You will hear it kick on. In most cases, if its low on freon it will shut down from low pressure then kick back on when the pressure rises in the system. Then shut down again.
Old Jun 11, 2006 | 04:54 PM
ByPopularDemand
So if the compressor didnt work it wouldnt blow at all
Old Jun 11, 2006 | 04:57 PM
monkeydude3's Avatar
monkeydude3
you really really need to check the state of charge before doing anything else
Old Jun 11, 2006 | 05:00 PM
ByPopularDemand
No shops are open today
Old Jun 11, 2006 | 05:40 PM
ShadowDrake's Avatar
ShadowDrake
Actually, the first thing I would check is your fuses. I've blown the A/C compressor clutch fuse before... if that happens, the A/C won't blow cold air and you won't hear the compressor kick on. If the compressor doesn't work, you won't get cold air is all. It'll still blow air out (like having it on any of the other settings).
Old Jun 11, 2006 | 06:04 PM
ByPopularDemand
Where is the a/c compressor
Old Jun 11, 2006 | 06:42 PM
monkeydude3
passenger side botton of engine bay... bottom pass. side of engine
vargas
Jun 17, 2017 12:17 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
