Tail light problem...help
Old Jun 17, 2006 | 12:04 AM
GT Tronics's Avatar
GT Tronics
Default Tail light problem...help
Im working on a 98 mustang, the LH side tail lights went out, no parking, brake or turn lamps. RH side works fine.
All wiring looks fine, Any ideas???
Old Jun 17, 2006 | 01:10 AM
GT_Bob's Avatar
GT_Bob
Default RE: Tail light problem...help
Considering your parking lamps and brake/turn lamps are on different circuits and the other side works fine, I'd check for a bad ground in the left hand (assuming drivers side), wire harness. Especially if the driver side fronts are working fine. That's assuming of course it's not a freak thing that all of your rear drivers side bulbs burnt out including the dual filament ones, (not likely). JMO
Good luck.
Old Jun 17, 2006 | 11:23 AM
GT Tronics's Avatar
GT Tronics
It does sound like a bad ground, but I can measure from the frame gnd. to the park or stop lamp wire at the harness connector and still no power.
Old Jun 18, 2006 | 12:45 AM
GT Tronics's Avatar
GT Tronics
Update:
I went back to work on it again and the lights were working....weird.
Thanks for the help tho.....
Old Jun 18, 2006 | 02:09 AM
GT_Bob's Avatar
GT_Bob
Sure sounds like a bad ground my friend. Glad they are working again though.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
