IAT relocation kit
IAT relocation kit
i got the IAT relo kit casue i switched to a lightning 90mm maf with my vortech. For anyone who has relocated the sensor in the inlet tubing after the blower and before the tb, what size did you drill the hole? I have the grommet type of plug in sensor.
RE: IAT relocation kit
i didnt buy the kit i just spliced in a foot or so of wire and drilled a 3/4 inch hole in the pipe between the tb and aftercooler. i then stuck the grommit in there and wrapped a second grommit towards the top of the sensor to prevent it from falling in. it was frustrating cause if you drill the hole too small there is no way to get the sensor through, too big and you gotta do what i did and use a second grommit.
ORIGINAL: mustang_montana
I can't remember for sure if I ended up using the 3/4 bit, but I just kept going up a size until I got it. I started with a 9/16 bit.
jwog666
12-27-2021 08:09 PM
