maf sensor
maf sensor
curious about a maf sensor will a lightning sensor work on my car just pluging it in so i can run 24lb injectors
or should i look for a mustang maf for a 99 gt cal'ed to 24lb injectors or is there an easier way
thanks for the help
thanks for the help
RE: maf sensor
Just curious, why would you want 24lb injectors? Thats a pretty minimal step up, and to spend the money, you might as well spend a little more and then you wont have to worry about upgrading again in the future.
RE: maf sensor
stock injectors are only 19s, i dont see how the slight jump to 24lbs would call for anything drastic. you could get the lightning maf for the hell of it, ive run it without a blower. you need a tune for it and the injectors though. i wouldnt switch to 24lbs, id stay with the 19s unless youre running a blower. but if you have to, get the lightning maf from frpp for like 80$ and get a tune for your setup.
jwog666
12-27-2021 08:09 PM
