dyno results
#21
RE: dyno results
ORIGINAL: mustang_montana
i forget the grand total, it was probably around 4 grand for everything, all the litle parts i broke, the fuel system etc. the only problem it has right now is the plugs are bad, and the o2 heater isnt working (i think the wires for the power source arent hooked up). other than that it runs perfect. the plugs are the culprit for the low numbers though.
Thats good news about the problem though. What plugs are you running?
#22
RE: dyno results
yeah the o2s arent heating up by themselves, which they are supposed to. instead they are heating up with the exhaust which takes a little while, which delays their reading. i got ngks, the 2 step colder ones. i think they just need to be cleaned off real good cause running as rich as i was, they are probably real black.
#23
RE: dyno results
You pulled the motor when you did all this right?
#24
RE: dyno results
huh? for the blower i didnt take the motor out. my theory is the 4th wire (the one to heat up the o2) isnt connected on either of the 2 front o2s, they are the bosch oem ones that you just plug in, no splicing. the problem with this is they dont have the 4th wire for the heating sorce. i gotta get underneath it tommorow, but i think i might have to get a pair of the universal o2s, which have all 4 wires...but need splicing [:@]
09-24-2015 09:18 PM
