Tires
Im ordering 18x9 DD for the front and 18x10 DD for the rear. Whats the best tires i can run on the front and rear. I want the widest i can go in the rear and the smallest in the front since im lowered and my 245 scrub a bit already. Maybe a 255 up front?
Now looking again at the site it has diff offsets and such. how do i know which i need?
WHEELS
I really want to fill out the fender wells to give it the beefy stance.
WHEELS
Any help would be appreciated. I dont want to get tires to wide and them scrub. I cant find a 18x8 BULLIT DD So i have to get the 18x9. Im thinking the 255 series will be ok. As for the rear its a 18x10 Wheel. Whats the largest tire i can do on the rear. Im looking at the BFGOODRICH Gforce T/A Drag Radial for the rear and the T/A KDW for the front. What do you guys think?Also any info on the offsets i should order from that site? When i get my paycheck this friday i will be ready to order the wheels.
Go to www.tirerack.com and www.discounttiredirect.com and read up on what is available and recommended for your car. You may also need a set of wheel spacers to keep from rubbing on the suspension. Check these out as they are quality made: www.maximummotorsports.com
Good luck with your ride!
ORIGINAL: mustangsel
Go with either 255 or 265 in the front. In the back go with either a 295 or a 305. Also, you shouldn't run DR's on the steet.
jwog666
Dec 27, 2021 08:09 PM
KingRando
Oct 2, 2015 08:06 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
