brake whine
RE: brake whine
ORIGINAL: sandcracker21
^^i will definatly try this later today or tomorow
that is wuts weird tho.....the sound only happens under light braking....
under heavier breaking its not there.....
and the sound only happens some of the time, somedays more than others
Try taking some 100 grit sand paper and sand them width wise. Get a grinder crosshatch your rotor surface or get your rotors rough cut. The sanding and rough cut/hatching keep the metallic dust from building up and causing the glaze that causes the squeal.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
