alright guys i need yalls help
RE: alright guys i need yalls help
don't know for sure, but if the timing were off, as in too advanced, and your running 87, and factoring in the new compression ratio you have with the new heads i'd say there is definately a chance of something going bad.
your car will make more power when its running on 91+. also, it may take a week or so for the computer to re-adjust itself to the new setup.
if you haven't already, take it down to the nearest gas station and top it off with premium.
anyway, congrats on the swap!
thats absolutly wrong, mustang actually do like cheap gas, once u change your timing or do major performance upgrades, then you can use 91 , so if thats what u meant than ur right, but stock or nearly stock mustangs should be using 87-89, no more than that because its actually worst for the engine
The noise was a loose cam gear bolt.( a redneck let me know right away.....
Well it ran like a dream for 2 days and i just snaped my timing chain[:@].
So no stang untill tuesday.....NO BUENO!!!!!!!!!!!!!!!
