UD pulleys install?
does the steeda Underdrive Pulley's need a puller for any of the pulleys?......or do they unbolt and slip off? does anything else need to come off to allow ease of installation? is steeda the best to get?
You'll need to pull your crankshaft pully off with a puller. As far as Steeda goes, I have heard they are good. The main thing everyone will tell you is to stay away from the piggyback systems(where your orginal crankshaft pully bolts onto the new one). I found it extremley easy to use a air impact wrench for the crankshaft and alternator pully. In order to gain access to the crankshaft pully, I had to remove the cooling fan(not hard at all). With the impact it took me about 60 min. It probally will take longer if you didn't use an impact because you would have to deal with the alternator and crankshaft pullys spining while trying to get them off. I personally do not recommed this mod. I think it is a waste of money. All I do is get crappy battery charge at night. Yes, at stoplights my lights go a little dimmer and my AC charge isn't that good. IMO, I would just get catback or some gears.
ORIGINAL: 98MustangSTLYou'll need to pull your crankshaft pully off with a puller. As far as Steeda goes, I have heard they are good. The main thing everyone will tell you is to stay away from the piggyback systems(where your orginal crankshaft pully bolts onto the new one). I found it extremley easy to use a air impact wrench for the crankshaft and alternator pully. In order to gain access to the crankshaft pully, I had to remove the cooling fan(not hard at all). With the impact it took me about 60 min. It probally will take longer if you didn't use an impact because you would have to deal with the alternator and crankshaft pullys spining while trying to get them off. I personally do not recommed this mod. I think it is a waste of money. All I do is get crappy battery charge at night. Yes, at stoplights my lights go a little dimmer and my AC charge isn't that good. IMO, I would just get catback or some gears.
