pullin a 4.6
RE: pullin a 4.6
The only advice I can offer is to take pics of every step as you go. If you get delayed on reassembly, they will help you to put everything back in the right places. Also, get twist ties or zip ties to hold any cables, wiring, or vaccum lines, and zip lock baggies for bolts and stuff (you can label them, ie, starter bolts, etc)
Good luck
Good luck
RE: pullin a 4.6
i use alot of baggies and label them with what i take off...first time it took a day with lots of brakes...next time itt took 2 hours with a friend. Don't unbolt the exhaust manifolds they come out on the engine and if your removing the tranny then leave that bolted up too...it also comes out bolted up.
10-09-2015 03:27 PM
