Spring Isolators or Not?
Old Aug 4, 2006 | 04:57 PM
suzukidragracer's Avatar
suzukidragracer
Default Spring Isolators or Not?
I recently bought lowering springs for my '02. The kit advertises 1.3" front and rear drop.
I would like to have a little bit of rake to the stance, not alot but slightly lower up front.
Can I cut the spring isolators or bump stops? I don't think I want to leave them out completely.
Are they thick enough to slice in half?
Would I cut the bump stops or the spring isolators?
Thanks,
Vince Woska
Old Aug 4, 2006 | 05:21 PM
Twister's Avatar
Twister
Default RE: Spring Isolators or Not?
don't cut the rubber...they are that size for a reason
Old Aug 4, 2006 | 05:52 PM
suzukidragracer
So you mean the bumpstops or isolators?
I've cut bumpstops before and it was very necessary to prevent bottoming while still keeping a travel restricted.
Old Aug 4, 2006 | 06:17 PM
suzukidragracer
Anyone have some more advice?
Old Aug 4, 2006 | 07:03 PM
Flyingmau5's Avatar
Flyingmau5
if you remove the isolators, you will see a 0.2"/0.3" drop to your stang...
Old Aug 4, 2006 | 07:12 PM
suzukidragracer
thanks!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
