Still have fuel problem
I have a 2000 gt. I pulled my pass side fuel rail off the injectors and turned on the ignition to turn on the fuel pump and fuel only came out only of the back two holes. I put it back on the injectors and pushed in the pressure relief valve on the front of the rail while the system was pressured and all i heard was a lil poof of air and thats it no fuel. When i once again pulled off the rail fuel came out of the back. I dont know if its my injectors or the rail is cloged... I pushed a zip tie through the whole rail no problem so it doesnt seem to be clogged. Idk any suggestions anyone???
RE: Still have fuel problem
When you say the back two holes, is that with the injectors or just the rail? If you had the injectors on, have you tried to run seafoam thru the fuel system? I hear that works well on injectors. Check the electrical connections on the other injectors.
If this is with the injectors off, then damned if I know.
zanemoseley
09-06-2015 12:58 PM
