A slight problem
Old Aug 16, 2006 | 05:10 AM
02StanGT's Avatar
02StanGT
Default RE: A slight problem
The clutch problem is your throwout bearing. You can either live with it for awhile, or replace it if you so desire.
Old Aug 16, 2006 | 11:31 AM
GodAmGT00's Avatar
GodAmGT00
Chatter from your clutch and also signal a worn/faulty Pressure Plate, or at worse, loose PP/Flywheel bolts (that's a little bit of a stretch though). I'm thinking it won't be loose hardware, since you'd have issues w/ engagement...
JT
Old Aug 16, 2006 | 01:26 PM
4.698GT's Avatar
4.698GT
Starting problem sounds like the fuel filter is clogged up, try changing that. The chatter sounds like someone didnt cut the flywheel last time the clutch was done.
Old Aug 16, 2006 | 01:54 PM
Donnie's GTS's Avatar
Donnie's GTS
Still has all original clutch, only 40,000mi on the car, so the clutch has never been redone.
Gene K
Oct 21, 2015 11:37 PM
stangin1996gt
Sep 21, 2015 11:01 AM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
