full bolt on car!
Old 08-18-2006, 04:53 AM
PerformanceRed4.6
PerformanceRed4.6's Avatar
Default RE: full bolt on car!
which should i get first...heads cam or intake? i dont know if i can get em all at same time...that would be like 4k dollars...but it will all be b4 end of winter...
PerformanceRed4.6 is offline
Old 08-18-2006, 04:56 AM
Airman21
Airman21's Avatar
i say intake first... if you do heads and cams you wanna do that at the same time
Airman21 is offline
Old 08-18-2006, 05:13 AM
GT_Bob
GT_Bob's Avatar
ORIGINAL: PerformanceRed4.6
If it was me, which it's not, so that's irrelevant, I'd decide what I want long term. Sit down and figure out what everything is going to cost, gains, benefits and what you want the car to be like when you are all done. Start from the finished product and work your way back. Using that method will save you a considerable amount of money. If you have to buy parts and sit on them until you can buy more, that's fine. Don't piece together parts and installs when it comes to the motor.
GT_Bob is offline
Old 08-18-2006, 06:24 AM
2000GT4.6
2000GT4.6's Avatar
u really think i will see 11s with bolt on car, stock bottom end, but heads cams and intake?
No way with the stock bottom end. I think code is gonna be hard pressed to see 11s with his setup, but no way with a 6K redline you will get there.
All of the power you make will be up top, but if you cannot rev over 6K the potential of the p-51 and agressive cams/heads will be wasted.
If you are not gonna put a bottom end in you might as well save your 4 grand and get a blower. Without the bottom end you will have to go with less agressive stuff and won't make the power you want.
2000GT4.6 is offline
msavoia23
12
07-07-2018 12:08 PM
cyclop5
10-03-2015 09:21 PM
Valkdriver
5.0L V8 Technical Discussions
08-13-2015 08:57 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: full bolt on car!
