Intake Wrap
I would actually think it would keep the intake hot. You wrap the exhaust so the heat doesnt dissapate through the exhaust and heat up your engine compartment, also a cooler exhaust flows slower than a hot exhaust. So wrapping your exhaust produces less back pressure. You should do that, not your intake.
ORIGINAL: Poobs
The idea is to keep the under hood heat from warming up your intake pipes so in this case wraping is doing the reverse of what it does for headers.
It would be cool if someone made a thermal intake. Like a thermis, mug. have a cylinder inside of a cylinder with a vacume of gas inside. That would keep the heat out... Or have it water cooled... http://home.howstuffworks.com/thermos2.htm
ORIGINAL: Aixtreme89
I know I have seen it done before. It may keep it cool. But have you ever touched your plastic intake after your motor has been running? Its atleast 120 degrees. the heat is going to transfer to the intake tube, then the isolation may retain that heat instead of wiking away.... But who knows
ORIGINAL: Poobs
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
