running lean
Old Aug 20, 2006 | 10:59 PM
ackuric's Avatar
ackuric
Default running lean
what could cause my stang to run lean? only mods are in sig. 75,000 miles. fuel filter changed within 10,000 miles.
replaced cracked intake about 6,000 miles ago or so.
Old Aug 20, 2006 | 11:11 PM
sitnlopro99gt's Avatar
sitnlopro99gt
Default RE: running lean
is it throwing any codes? 02sensors could be failing would be the onlything really if its mostly stock I would imagine. Could also possibly be your intake setup that changes your a/f quite a bit
Old Aug 20, 2006 | 11:17 PM
ackuric's Avatar
ackuric
replaced w/ stock intake w/ one with an aluminum crossover.
no codes thrown. arent the front o2's a pita?
Old Aug 20, 2006 | 11:20 PM
sitnlopro99gt
pita as far as replacing? as simple as jacking it up and stickin a long thin flathead up the side of the tranny to release clip and they make a special o2sensor socket you can get a an autoparts store so you dont f it ^ when trying to take off and put on.
Old Aug 20, 2006 | 11:36 PM
code3GT's Avatar
code3GT
Mustang Nazi
How lean?
Old Aug 20, 2006 | 11:46 PM
ackuric's Avatar
ackuric
i've had my spark plugs in since my intake replacement (6,000 miles or so) and the electrodes, or w/ the white tip is called, is still really white, no haze, glaze. but the metal prongs has a lil haze.
Old Aug 20, 2006 | 11:47 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: ackuric
i've had my spark plugs in since my intake replacement (6,000 miles or so) and the electrods, or w/ the white tip is called, is still really white, no haze, glaze. but the metal prongs have a lil haze.
Get it on a dyno and check A/F.
Jb145700
Aug 21, 2022 06:37 AM
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
uedlose
Sep 10, 2015 03:30 PM
