Changing Shocks?
Old Aug 20, 2006 | 11:11 PM
red99droptop's Avatar
red99droptop
Default Changing Shocks?
I was just curious about how easy it is to replace my shocks on 99 gt. I replaced them on my motorcycle and it was simple. Is there any problems I may run into.
Thanks
Old Aug 20, 2006 | 11:15 PM
4.698GT's Avatar
4.698GT
Default RE: Changing Shocks?
Probably not, the front Struts are a liittle more trouble some if you dont have any air tools though
sitnlopro99gt's Avatar
sitnlopro99gt
easy as pie, Rears are as simple as jacking up the back put the stands have the floor jack raise the rear till the pressure is released from the shocks enough to undo bolt and trying to fit in the back inside of the trunk to losin the top bolt to pull the shocks out took me about 30 mins to do both and then pull right out. Fronts are just as easy. If youve ever done springs its basically the same first 5 steps. Good luck Dan-
2007StangV6
Jan 28, 2016 06:09 PM
guitarman376
Oct 11, 2015 01:47 AM
67STANGX2
Sep 24, 2015 12:29 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
