spec?
08-29-2006, 08:46 PM
spec?
has anyone used the spec steel flywheel? how light is it compard to stock? is it a noticable differance.
08-29-2006, 09:30 PM
RE: spec?
anyone?
RE: spec?
The specs billet steel one weighs the same which is 25lbs. im not sure how much the aluminum one weighs.
08-29-2006, 09:37 PM
RE: spec?
so is it a waste to get the steel one, should i just resurface my stock flywheel. is there going to be no performance gain?
08-29-2006, 10:21 PM
RE: spec?
does anyone know if there will be any performace gains
08-29-2006, 10:36 PM
RE: spec?
I have the steel one along with my spec stage 1 clutch. the car shifts and revs alot smoother now.
08-29-2006, 10:44 PM
RE: spec?
i know the clutch was worth the money, but was the flywheel worth the money spent? is there any acceleration differance
08-30-2006, 12:27 AM
Chupacabra
RE: spec?
I got the the steel spec flywheel when i did my motor swap and a spec clutch, and it seems alot smother than a new clutch + a resurface, but in my situation i needed a new flywheel because of the different bolt pattern on the cobra crank.
baddog671
07-26-2016 01:20 PM
robcy
Suspension
10-27-2015 11:14 PM
Cavedawg
09-17-2015 09:51 AM
EASTIDEE123
09-14-2015 03:52 PM
Webster454
09-07-2015 04:59 AM
