cam write-up
RE: cam write-up
ORIGINAL: racer02GTstang
well... this is how i did my cams..
i took off both valve covers.... pain in the ***.. you may have to remove other things to get them out
then i removed the cam gear bolts and slid off the cam gear with either zipties or something on it to keep the timing from being screwed up.
then i unbolted the cams and picked them straight out of the motor. i put the new cams in and bolted them down close to where they should be in timing... then i turned the cams till they were lined up with the cam gear and slid the gear back over the cam... this can take alittle work but its possible...
RE: cam write-up
I did it the same way just last week. I didnt even use zip ties. I loosened the cam caps, then I just slid the timing gear off the cam and pulled up on it to hold tension. Then I changed out the cam with my other hand and then slid the gear back on the new cam. It fired right up and its still in time. Its a pain in the butt but it can be done.
RE: cam write-up
I wouldn't do it that way on my car but others have done that and not had issues..I would remove the timing cover atleast so you can watch to make sure you don't skip a tooth and have real issues. Its only about $15 worth of timing covers gaskets that need to be replaced.
RE: cam write-up
Well, heres where my situation differs from yours. I installed the valve springs and cams the first time over last winter. I took everything off, timing cover included. I followed the write up from modulardepot.com, and Id say it took me about 5 to 6 days of working on it about 2-3 hours a day. I wasnt satisfied with the Crower cams, so I ordered VT cams. Since the springs were already installed, it was simple enough to short cut the job to switch out the cams. If you are doing springs, I would definitely take the cover off, because your gonna have a lot more things to pay attention to other then keeping tension on that cam gear...
junior04
09-28-2015 10:53 AM
